2010 civic type r 410 injector base map
micky.dawson
Post by micky.dawson »
hi all new to all this ive been and purchased the rdx 410 injectors with flash pro from tegiwa. now im stuck on what i need to do with getting them to work where do i get a download from to get thisto run its a standard car and i wanna keep it standard. only reason we have changed to bigger injectors is honda cant get them anymore
any help would be fantastic
cheers
Re: 2010 civic type r 410 injector base map
You must set the correct injectors and dead times in the calibration and then may need to tune it on the dyno to fine tune the AF ratio.
micky.dawson
where do i find the dead times from never used this equipment before. im assuming once i plug in and go to hiondata vaults you find the base maps
New calibrations can be opened by clicking on the New Calibration button. Go to the fuel section of the calibration window once a calibration is opened.
The dead times for the injectors should be provided by the manufacturer. Make sure the injectors are genuine as the fake ones cause problems for most people.
