K20/K24 cam° constant 107
LostMyQuise
Post by LostMyQuise »
Hi all I was wondering if anyone out there had a basemap designed specifically for a k20/k24a2. The basemap Im using is the 04-05 TSX on 91 and my cam degree is constantly at 107 which is making my fuel table stay in the 50 degree table same with ignition. The car drives fine for awhile but then the idle stays at almost 2k and I have to depress the clutch until my idle goes back to about 1200. The mods are as follows:
Stock k20a2 head
K24a2 bottom
Type-s oil pump
Aem cold air intake
Acuity TPS
Deatschwerks 1000cc injs
Skunk2 alpha header
Ktuned 72mm TB
RBC Manifold
Stock fuel pump but I have a Deatschwerks 265lph pump ready to go
Any help would be appreciated. Thank you
CalibratEd
Re: K20/K24 cam° constant 107
Post by CalibratEd »
Post the calibration file you are using along with with a datalog of the issue. It sounds like you may have a mechanical or electrical issue.
-Ed
Instagram: calibrated.tuning
