-20 Cam signal/ Crank no start
jdm_express
Post by jdm_express »
Hello,
I've tried looking this issue up on just about every forum but unfortunately my situation is a bit different then everyone else. I have a 04 RSX Type-S (k20A2) stock ecu with kpro v4, turbo with AEM wide band. Car has been doing great for the past year. About 2 weeks ago it shut off on me going down hill. I restarted it no problem ran fine for 20 minutes then dide on me in the middle of the intersection. Got it started after a few times of cranking it. Got it to my shop and plugged in my computer and noticed -20 cam with 0 on cam command. Normally it's 0 on both. No check engine light so nothing on the error codes. Looked at the wiring from ecu to firewall and inside engine bay. Nothing seems to burnt or broken or chewed up. I tested both connector ends on the wire side, both have power. Also tested sensors and ended up replacing them just for good measure, nothing changed and still getting -20 for the cam, Any ideas? Thanks.
Re: -20 Cam signal/ Crank no start
Have you checked the mechanical timing?
jdm_express
No, not yet. I'll do that next thanks.
