05 Element YH2 JDM K24A RBB2 E-tune support
Hey new to the whole forum thing just wondering if someone could look over my Kal to see where I butchered the hell out of it....
so it all started when I replace the RDX injectors with Bosch 2200cc it was running perfect but i am getting ready to boost it and I'm a builder not a tuner lol also the injectors don't like the values not sure if I screw that up also I am sure I either burnt a coil or a plug getting the data I'm uploading anyone could take a look and tell me if I destroyed my tune or if its savable I would really appreciate it so much thanks
05 Element YH2
JDM K24A RBB2
50 degree
Ported type s pump
70mm tb ported cloned sk2 intake mani
and short ram intake
TSX 6 speed gears AWD Trans
2200cc Bosch Fuel injectors
fuel pressure is 45 idle-50 Wot
WALBRO 525LPH
AEM wideband wired to kpro v4
05 Element YH2
JDM K24A RBB2
50 degree
Ported type s pump
WALBRO 525LPH
- CalibratEd
- Contact:
Re: 05 Element YH2 JDM K24A RBB2 E-tune support
Solo,
Do you still need help with this? I apologize I thought I had replied to your thread.
-Ed
-Ed
Instagram: calibrated.tuning
I do but unfortunately i can't do anything for a while have to recover from a surgery
- CalibratEd
- Contact:
Wow, get well soon. Reach out once you’re ready.solokick3 wrote: Mon Nov 07, 2022 1:02 pm I do but unfortunately i can't do anything for a while have to recover from a surgery
-Ed
Hey Ed I'm back 90% recovered, I also have a different ecu so I kinda borrowed the last tune you did for Burgturdler the BurgturdlerRev28 and did a few modifications to get it running but it actually runs very well with only a few hiccup's as you will see if you look at the kdl's sorry they are a mess but its not a easy task when your alone trying to data log lol... im not sure about the injector settings also but here is the mess i came up with from your tune enjoy 😂🤣
- CalibratEd
- Contact:
I'm glad to hear you are doing well. I looked over the files. You are brave for loading a random file and wide open throttling the car. In its current state it is running rich. I always recommend starting from a base file because if you don't you may end up chasing your tail.
Also, when you changed the injectors did you change deadtimes as well?
-Ed
-Ed
Honestly i cant get it to run on the supplied dead times
- CalibratEd
- Contact:
Does it not idle? Do you have a log and calibration file of when you modified the deadtimes?
-Ed
yea I cant get it to idle no IAC doesn't help either
- CalibratEd
- Contact:
Its best to have the deadtimes set correctly as you can have issue later on. I suggest to start with a base file and then add fuel as needed until you can get it to idle. Have you boosted the car yet?
-Ed
Its in it just in the wrong spot its in the back waiting for the snow to melt
- CalibratEd
- Contact:
I will try to get a base together. When does your snow season end?
-Ed
-Ed
should be clear by the end of march also let me know if you want i can give you access to team view on a weekend or evening after 6pm est
Then I wake up the next day 🤣
- CalibratEd
- Contact:
