Ignition timing table not showing psi
aconforti
Post by aconforti »
When on the ignition timing table, it’s only showing in “ or mbar. I can’t get it to show psi. I tried options->units->psi. And I tried “show boost tables”. I also tried loading in a tune from the vault that would be for a turbo engine. Not sure what else to do.
Re: Ignition timing table not showing psi
What do you have checked in the options menu?
aconforti
Post by aconforti »
Spunkster wrote: Mon Sep 26, 2022 10:49 am What do you have checked in the options menu?
Under units for vacuum, I have inches checked and atmospheric checked, and then under boost, I have psi and atmospheric
Those are not on the options menu in the software.
aconforti
Post by aconforti »
Spunkster wrote: Mon Sep 26, 2022 12:30 pm Those are not on the options menu in the software.
Okay, I just loaded up smanager. Under options: "Tables follow VTEC" and "Show boost tables (0-1.8 bar)" are checked.
And when you go to Options, Settings, what is checked on the unit tab?
aconforti
Post by aconforti »
Spunkster wrote: Mon Sep 26, 2022 1:04 pm And when you go to Options, Settings, what is checked on the unit tab?
It looks like it is displaying correctly in the background.
aconforti
Post by aconforti »
Spunkster wrote: Mon Sep 26, 2022 1:13 pm It looks like it is displaying correctly in the background.
It's displaying as Inches (")
looks normal
aconforti
Post by aconforti »
Spunkster wrote: Mon Sep 26, 2022 1:18 pmlooks normal
I may just be confused then lol. So col 9 is -0.8 inches of vacuum. Would col 10 be 0.4 psi since its positive?
that's correct.
aconforti
Post by aconforti »
Spunkster wrote: Mon Sep 26, 2022 1:28 pm that's correct.
This all makes so much more sense now. Sorry i'm new to all of this, and thank you for the help!
