Is Hondata cross-compatible?
chunglygamer
Post by chunglygamer »
So I've cane across a youtube vid where a youtuber stated hondata is not cross-compatible like k-tuner. For example, if I bought my flashpro specifically for the 1.5T (civic Si), then I can't use hondata on other honda platforms such as the type-r because different engine.
Correct me if im wrong, but if you buy hondata, it should be compatible for all honda as long as there's a basemap for it on the dtopdown list. All it requires is that it needs to be unlocked from the specific car you've flashed it to. For example, I currently have flashpro locked on to my Si. If I want to flash my Type-R (not that I have one), all I would need to do is unlock it from my Si, lock it on to the Type-r, and should be good to go. You don't need to buy a whole new hondata flashpro specifically for the Si, non-Si, or type-r. Am I wrong?
Re: Is Hondata cross-compatible?
The ECUs that each FlashPro will work with are listed on the Specification tab of each FlashPro product page.
