rsx with k20z3 transmission speedo help
stephen69x
Post by stephen69x »
so i have the kprov4 2002 rsx type s is the car full k20z3 swap. rywire 02 type s harness. trying to get the speedo to work correctly without pegging it going only 3 mph. i know this ecu has the capability to do this via vss output via b11 output what wires do i need to reroute re work to get this to work properly
Re: rsx with k20z3 transmission speedo help
