P1361 with new KPro
jeremy_es1k
P1361 with new KPro
Post by jeremy_es1k »
Good evening everyone,
Upon connecting my new KPro in my car, I experienced an issue I’ve never seen before, code P1361 - TDC Intermittent Signal.. car cranks but no start.
Following Hondas service technician book,
I have verified my wiring for the crank position sensor and there are no shortage,
With the key set the on position (II), I have tested the voltage / ground on the 3 pins of the CKP connector, everything seems fine as well.
I then proceeded to swap the crank position sensor with a new one and I’m still running into the same check engine code.
Following that, I installed a new engine harness , still running into the same issue here.
Car was running like a dream before taking out the ecu.
Is it possible the new ecu replacement/kpro is faulty ?
What else should I look out for ?
Thanks in advance for everyone help,
-Jeremy
~Jeremy
@jeremy_es1k
Civic ES1 K24/20 6spd
Re: P1361 with new KPro
You need to try the ECU on a known working vehicle and see if the problem follows the ECU.
