8th Gen BASEMAP HELP: 12:5:1
jsutnick
Post by jsutnick »
Does anyone have a similar set up and can get me going in the right direction so the motor doesnt blow on the way to get tuned tomorrow morning.
2007 civic si
hybrid intake 3.5, alpha header, q300
k24a4 bottom end 87.5x99
12:5:1 pistons
stock port z3 head
supertech valvetrain and skunk 2 stage 3 cams
rrc ctr oil pump
rbc
pump gas 93
CalibratEd
Re: 8th Gen BASEMAP HELP: 12:5:1
Post by CalibratEd »
jsutnick wrote: Mon Oct 24, 2022 11:42 am Does anyone have a similar set up and can get me going in the right direction so the motor doesnt blow on the way to get tuned tomorrow morning.
2007 civic si
12:5:1 pistons
stock port z3 head
rrc ctr oil pump
rbc
pump gas 93
Post the calibration file you are running along with a log. I can make sure the fuel is ok for you to run.
Im sure as long as you don't wide open throttle the car you can make it to your tuner.
Also, it never hurts to ask your tuner for a base map to get you to them.
-Ed
Instagram: calibrated.tuning
