I registered because I need help!
FlashPro questions & answers specific to the 2007-2008 Acura TL
Tootsee
Post by Tootsee »
I want to know Oh if you could help me I have a 2006 Acura TL automatic base with navigation and TPMS I recently swapped in a 2008 Acura TL type S also automatic
The swap was successful everything works in the car transmission engine run smooth the only problem I have it is the ECU cannot connect to scanners cheap scanners read no link more expensive scanners reads no communication so I have a check engine light on and the scanners won’t read the ECU I also have the airbag light on VSA And traction control light
Please give me some advice on what to do to be able to read my ECU so I can pass inspection
things that was swapped
Engine transmission subframe ECU engine wire harness key immobilizer all from 2008 Acura TL type s automatic
Re: I registered because I need help!
I'm sorry, but this is not something we can assist with.
