K pro not working
MoeNyc
K pro not working
Post by MoeNyc »
My k pro is stuck in limp mode. I tried in another car and also ran the same so I know it’s the k pro. I think I may shorted the ecu but I’m not sure board looks good to my eye. Is this fixable? Or do I have to get a new one? Please help
Re: K pro not working
What errors are there when you datalog?
MoeNyc
Post by MoeNyc »
37820-PND-A07
2062-805298 of 06
And I get no errors because the ecu freezes setting on manager
Tried erasing ecu didn’t work
Ecu would start communicating to laptop with no key in ignition. K manager I assume was on last eat software because my mechanical reinstalled it. Not to sure what version.
MoeNyc
Post by MoeNyc »
Did I not give the right number? Where do I find that?
MoeNyc
Post by MoeNyc »
It’s version 4.5.3.0
You still have not given the K-Pro serial number.
MoeNyc
Post by MoeNyc »
2062-805298
Is it not that?
No that is not the serial number that is on the K-Pro board inside the ECU. That is the ECU part number.
MoeNyc
Post by MoeNyc »
I see T1Y-D3
Is it that?
MoeNyc
Post by MoeNyc »
Found it it’s 58671
What vehicle is this being used on?
MoeNyc
Post by MoeNyc »
2005 base model rsx
What have you done that makes you think you may have shorted the ECU?
MoeNyc
Post by MoeNyc »
I was testing voltage to the speed sensor seeing if anything went out because it was raining bad and I got a cel for speed sensor malfunctioning
