TPS calibration issues
Ichiro718
Post by Ichiro718 »
Hello again, I calibrated my TPS and I'm getting 4% closed, and 105% open. I did mess around with my TB cable and bracket. Should i try getting it close to 0% as I can?
Re: TPS calibration issues
if it reads 0 and 100 datalogging then it should be ok.
I try to get the calibration as lose to 0 and 100 as possible without any correction though.
Ichiro718
Post by Ichiro718 »
In data logging, 4% is with throttle closed and WOT is 104%. I had to do some custom fabrication a whole back and it involved the cable. The reason why I'm pointing to the cable needing adjusting is because it's off by 5%. I'm going to slack up the cable a tiny bit and see if it gets me closer. I'm trying to shoot for like 1%-98-99%.
