Loss power when run a Wot Civic 1.5t
Civic 2016+ 1.5 Turbo
Salvador Rivera
Post by Salvador Rivera »
Yesterday I was running my civic a Wot, but when get 55mph the cars feels like jerking then, afortonally I save the datalog, I think the problem is in the fuel because when I see the datalog the AFR was in 9.50 , it could be problem of Injectors ? My spark are in a Good conditions.
Re: Loss power when run a Wot Civic 1.5t
You appear to be letting off the throttle around that speed.
Salvador Rivera
It´s the same for the loss of power, the fuel pum get Higher pressure
Salvador Rivera
Today I run again the Civic at Wot in the missfare came in the Cylinder P0304, then I turn the car off, I star the car again and the error code dissapear, I think the coil is the problem. I attach the Datalog.
It is misfiring because it is running very rich. You need to fix that first.
