Mod list:
Skunk2 Stage 3 Tuner cams w/ 45 degree gears
95lb supertech kit
Ported/cut rbc intake manifold
72mm ktuned tb w/ acuity tps
hybrid racing fuel rail center feed w stock rsx injectors
hybrid racing intake
stage 4 cc clutch and lightweight flywheel
skunk2 megapower RR 3in exhaust
skunk2 alpha header
Searching for a basemap to get it started. Any recommendations? Was thinking about using a Kpro base tune for the brian crower cams and toda stuff as a start up.
K20A2 Semi-built calibration
Re: K20A2 Semi-built calibration
Side note will be replacing the injectors with 1300cc injectors and flexfuel for e85 but just want to get It started initially after the rebuild.
- CalibratEd
- Contact:
I suggest you start with a stock base map and make adjustments per your modifications.soflushed wrote: Wed Nov 30, 2022 7:55 pm Mod list:
95lb supertech kit
skunk2 alpha header
-Ed
Instagram: calibrated.tuning
