FlashPro killed the sport mode
FlashPro questions & answers specific to the 2008+ Accord, Americas and international
rainy187
Post by rainy187 »
i have 2018 2.0 AT, ever since i flashed the flex fuel calibration. the Sport mode became so weak, does any one else have the same issue?
sport mode used to be so fun to drive even with just little throttle you can see the boost increase on the dashboard. now i need to step on throttle way harder than before to see the boost go up. and i don't see any option or setting for the sports mode on flashpro manager 4.0.20
Re: FlashPro killed the sport mode
Do you have a flex fuel sensor and controller installed?
rainy187
Post by rainy187 »
yes sir, i did. however fuel is not the problem. how come there is no sports mode setting on the flashpro manager?
Do you have the ECON button boost enabled?
rainy187
Post by rainy187 »
it was on as default. so, yes it is enabled. Accord got 2 buttons though.
We do not alter how the sport button works on the Accord.
rainy187
Post by rainy187 »
Then why its not the same as before, it got weaker. For the next update, can you guys put it back to where it was before?
rainy187
Post by rainy187 »
I found it, once i disabled hondata mode. my sports mode is back to normal, and the econ button worked as well.
