Maximum timing
LittleH
Maximum timing
Post by LittleH »
Hello guys , newbie here in the world of the s300 in general , have it for almost a week.
I have a b20vtec bottom end stock , have b18c-r cams , upgrades valvespring + valves , b16 IM , skunk2 70mm TB , 60mm exhaust with UEL headers.
We are in the process of tuning the car and we were wondering if we can make it pop and bang when letting go of the throttle , but we saw that ignition table will only give -4 degrees of max retard , is there any way to add more retard when letting go of the throttle for specific rpm range , for example from 3k - 1.5k or something similar.
Thank you in advance -Jason
Re: Maximum timing
No this is not possible as it is mechanically limited. Causing it to pop and bang is not good for the engine.
LittleH
Re: Maximum timing
Post by LittleH »
Thank you so much for the fast reply , I am aware , due to we tune with some custom ecus , our other cars , first time on hondata , but thank you , guess -4 will suffice
