Coolant thermostat temperature check (P0128)
FlashPro questions & answers specific to the 2008+ Accord, Americas and international
rainy187
Post by rainy187 »
Do we need to have Coolant thermostat temperature check enabled (P0128) unchecked for the flex fuel calibration?
if it is unchecked, how or where would the car get that information from?
Re: Coolant thermostat temperature check (P0128)
What vehicle are you referring to?
rainy187
Post by rainy187 »
sorry, its 2018 accord 2.0 AT with flex fuel kit
Are you getting an error code?
Do you have it checked or unchecked?
10thGenE
Post by 10thGenE »
i had the same issue with my 2019 accord 2.0 and had the Coolant thermostat temperature check (P0128) unchecked.
Post your calibration as well as a datalog showing the issue.
leroy
Post by leroy »
how do you fix this keeps on doing the same thing and its annoying
rainy187
Post by rainy187 »
i have mine unchecked and i have no error codes, i am just wondering if i have it unchecked, would the car will check the temperature or ignore it?
leroy
Post by leroy »
How do I do that?? Uncheck it ?
rainy187
Post by rainy187 »
in the Calibration, under Misc, you will see it there
