Hondata S300 V3 Cannot upload or datalog
majdi_mohammad
Post by majdi_mohammad »
Hello and good day all. I have hondata s300 v3 JDM that cannot upload and datalog. The button for upload and datalog grey out cannot click. Only can view s300 information that not show any problem.
Car running well no check light. The problem only cannot do anything to tune...i try with others 3 working ecu, no luck to make it work. Pretty sure it not ecu problem.
1. LED 4 ON direct when igniton key ON, LED D3 ON like 3 second and OFF. start engine all good.
2. LED 4 ON direct when i plugin USB cable, LED D3 ON like 3 second and OFF, LED D2 blinking continuously. And it show ON LINE in smanager.
3. I open calibration in smanager, and turn the ignition key ON. Noting happen, it should show start/stop datalogging button available, but it just grey and cannot click.
4. Also check CN2 connection from ecu to hondata all have connection and no open circuit..
It is possible hondata problem not detecting cn2 connection?
Re: Hondata S300 V3 Cannot upload or datalog
What is the part number of the ECU this is installed in?
VtecGarage
Post by VtecGarage »
Exact same problem Im having too
majdi_mohammad
Spunkster wrote: Fri Dec 23, 2022 10:09 am What is the part number of the ECU this is installed in?
ECU P30-N01
S300J 5335 white board
Smanager V2.8.1.0 build 2966
majdi_mohammad
VtecGarage wrote: Fri Dec 23, 2022 3:28 pm Exact same problem Im having too
Have you try difference ecu? I tried 3 known working ecu no luck
VtecGarage
No but I have a virgin ecu Im sending off to have vtec installed and new capacitors put in it. Also have all the S300 install kit put in with it
majdi_mohammad
T try new hondata today. Sure ecu is ok. I got faulty hondata that not detect the ecu it turn ON.
The new hondata will light up LED D3 static after Ignition key is on, and LED D2 will blinging after usb is plugin.
majdi_mohammad
I got internal short at U1. 5V from cn2 to U1 LPC1768FBD100 pin 88.. Resistance form GND to 5V should be R43 10K. Do Hondata sell spare part for replacement U1?
We do not offer replacement parts for the s300.
As it is out of warranty, you will have to pay for a replacement s300 circuit board.
send an email to support <at> hondata.com with the following and I will issue an RMA and give you further
instructions:
Name:
Address:
Phone:
Email:
Serial#:
Description of problem:
Include a link to this thread.
majdi_mohammad
Alright. Will email the detail.
racewerks
Post by racewerks »
I have same issue with s300 cannot upload red led keeps flashing
Soldering is all good
Checked with socket tester
Doubled checked with multi meter for continuity
Not sure what is the issue
Software version 2.8.7.0
Serial number : 34805
Firmware : 22
Please let me know what could be the issue and how to move forward
When was the last time it was working?
What has changed since then?
racewerks
Post by racewerks »
Nothing changed this was in my friends car and when he tried to upload a map dint work so he gave it to me to check.
I updated to the latest software and tried checking nothing works
Checked all soldering and checked with chip tester for all pins
No cold solder all components look good and soldering looks good checked continuity using multimeter across the pins.
Should we connect remotely? To check ?
Send an email to support <at> hondata.com with the following and I will issue an RMA and give you further
instructions:
Name:
Address:
Phone:
Email:
Serial#:
