Pnd auto vss question
Pjj5025
Post by Pjj5025 »
Hello,
Doing some research while my auto Pnd ecu is with you guys having kpro installed.
After repining the vss wires to work with a css sensor and running the signal to the alternate speed input is there a recommended starting point for the pulses per km for the css sensor?
I see the vss recommendation is 2485 just curious If there was a different number for the css?
Also with the Pnd auto ecu will I be able to use b11 or another speed output to control an eg cluster with the kpro v4 ? I seen one post saying someone was able to use b11 with the Pnd auto and I seen another post where it said that this is not possible with the auto Pnd ecu and will need the converter.
Not a huge deal but just curious so I don’t waste time trying to make it work if not possible.
Attached pic with ecu serial.
Thanks again for any info,
Pat
Re: Pnd auto vss question
If the ECU was not prepared by Hondata then it will not have a VSS output form the ECU.
You will have to try the setting shown then alter them as needed for your setup. You should use the same settings as if countershaft speed sensor is selected.
Pjj5025
Post by Pjj5025 »
Perfect - thanks ! It is with hondata now being installed so hopefully the output will work. Wasn’t sure if it being from a auto would make a difference.
