HONDATA app on iOS does not automatically reconnect to Bluetooth
yakutanoki
Post by yakutanoki »
# Various versions
FlashPro manager : 4.0.3.0
iOS : 16.2 (iphone12mini) & 12.5.6 (iPhone5s) *The problem occurs on both devices.
iOS application : 1.4.1
# Incident
After connecting FlashPro and iPhone, I can use it for about 10 minutes without any problem.
However, suddenly the sensor value is not updated.
The app seems to maintain the connection with FlashPro, but the values are not updated.
If I task kill the app once and then restart it, it stays in the "Searching" state and does not reconnect.
If I perform an unplug and plug FlashPro from OBD (restart FlashPro), it will be able to connect again.
However, the same problem occurs again after about 10 to 15 minutes.
I would like to solve this problem as soon as possible, because it is very difficult to restart FlashPro many times.
Translated with www.DeepL.com/Translator (free version)
Re: HONDATA app on iOS does not automatically reconnect to Bluetooth
What is the serial number that is on the FlashPro?
yakutanoki
Thanks for the reply.
The serial number is as follows
#221789
yakutanoki
Thanks.
Do I need to "send feedback" when an event is occurring?
Or is it ok to "send feedback" when Flashpro and iPhone have a good Bluetooth connection?
yakutanoki
I have sent two pieces of feedback.
#1.
After getting into my car, with the ignition on, but not the engine running.
Flashpro,iPhone5s connected and sending feedback.
I think I am in the car with no problems.
#2.
After 5 minutes of driving, the values displayed on the iPhone stopped updating, so I sent feedback with the iPhone in that state.
I think I am in a state of having a problem with my car.
Thank you for your patience and please check back with us.
Our software engineers have been made aware of this and are looking into it.
Ziradon
Post by Ziradon »
It seems this problem is back with 4.0.5.
Today i had lost connection about every 10 minutes. If i replug the obd it works for some time and than the app loose connection and so on.
2020 Honda Civic Type R - European Edition
yakutanoki
It seems that the iOS app has undergone several updates, but this issue has not yet been resolved. If the connection is lost, you need to unplug and plug in the OBD connector. In addition, you can restore it by toggling the Bluetooth checkbox for FlashPro within FlashPro Manager.
I thought that if there was an option to toggle Bluetooth OFF/ON for FlashPro every 5 minutes, it could be a temporary solution.
By the way, it appears that the HONDATA app can no longer be downloaded in Japan. Has the app's updates been discontinued? Hondata Complete is still available for download in Japan, though.
yakutanoki
What is the status of the investigation of this issue?
Much time has passed since we inquired.
This is a paid application and I would like to see a proper response.
Please check with us as we are really troubled.
We have extensively tested the app on both IOS and Android with all versions of the FlashPro and have not been able to reproduce any issues like this.
Scoliosis_Speedrun
Post by Scoliosis_Speedrun »
I am experiencing symptoms identical to this. Flashpro used on a FA5.
yakutanoki
This issue has finally been fixed in the following environments
FlashPro 4.2.5
HONDATA App 1.6.3
We hope this problem will not recur in the future.
Thank you very much for your support.
