AT to MT questions
rustyfender
AT to MT questions
Post by rustyfender »
hey so for starters im new to workin with honda engines. but im an experienced wrench. that being said i am using a k24z3 to swap into a 1970 MGb with it mated to a miata 5 speed. the engine i picked up has a 37820-rl5-a56 ecu its from an automatic 2012 TSX. what im wondering is if i can flash a manual transmission calibration to this ECU. Or if i can just omit the wiring for the automatic and remove the related error codes. it would be nice to have speed run to the ecu from teh transmission tho if i can make that happen.
my reasoning is that id like to run canbus for what i can to help reduce the amount off wire i have to run through the car.
Re: AT to MT questions
No you cannot change it from auto to manual, and the FlashPro is not designed for use with engine swaps.
antisocial
Post by antisocial »
@OP, you need to get with KPower industries, they have a crank sensor swap setup that will allow you to run this engine with KPro in that swap
