Base map for k24 turbo please
Kaytweenie
Post by Kaytweenie »
I need a base map, just so I can start my car up to roll it around the house and test the brakes and ect. Will be getting tuned soon.
The setup is
1994 Civic Hatch
Jdm 2004 k24 3 lobe rbb-2
Jdm 2004 Crv Awd Transmission
Block is stock besides ported type s oil pump
Head has supertech 97lb spring and retainers and a skunk2 pro series manifold with 74mm throttle body, no iacv no purge
50 degree Vtc have a 40 degree pin in it
Hondata 4bar map sensor
Id1300x injectors
Turbo: Precision 6266
Sidewinder manifold
4 port boost solenoid
New oem Denso primary o2 sensor/wideband
Stock oem coils
If anyone could help me setup a base map to just start the car would be awesome
Thank you
Prb Kpro ecu
Kaytweenie
Re: Base map for k24 turbo please
will be set at 50 fuel pressure
CalibratEd
Post by CalibratEd »
When do yo plan to get the car tuned?
-Ed
Instagram: calibrated.tuning
