2023 Civic Si -- Working?
Civic 2016+ 1.5 Turbo
conleec
Post by conleec »
I just traded in my 2019 Civic Si for a 2023 11th gen. Will my same FlashPro work on the new car? Are there profiles for the 2023 model yet? Thanks in advance.
Re: 2023 Civic Si -- Working?
What is your ECU part number?
conleec
Post by conleec »
Without taking the thing out, there is just no way I can tell. I've put my phone down the narrow gap between the intake and the ECU dozens of times with flash and without, video and stills, and there just isn't enough room to get a good pic of the sticker. But I'm assuming it's not supported, because when I tried to lock the unit to my car, it reported an unknown profile, which I uploaded to Hondata.
Then you will have to wait until it is supported. Without the ECU part number there is no way for us to check it.
conleec
Post by conleec »
Spunkster wrote: Mon Jan 09, 2023 10:12 am Then you will have to wait until it is supported. Without the ECU part number there is no way for us to check it.
That's no problem. I already owned the FlashPro. Can I assume if I try one day to lock to my car and it allows me to, that it is safe to proceed, and there will be a CARB profile available for download?
Chris
YOu will have to check for software updates that allow your ECU part number to work with it.
conleec
Post by conleec »
Hmm. And that damn sticker is the ONLY way to tell the number? It's impossible without removing the unit. Maybe the 2022s were different.
C
