12 si RPM dip and random stft problem
wkl1993
Post by wkl1993 »
dont have idea where the problems are at
car got 410cc rdx injector
zdx throttle body
2.5 inch exhaust
header
skunk 2 manifold
rbb head
dc5 cam
light flywheel
idle drop around 0:56
strange stft after 4:00
hope some one can explain where i did worng
things i did
make change on the tb flow chart
injector size and latency
fuel pressure
fuel cut and recover rpm
road tuned
any help and suggestion would be appreciated. thanks!
Re: 12 si RPM dip and random stft problem
It could be the dead times for the injectors or the non-OEM throttle body. Using larger throttle bodies usually causes issues as they have different characteristics that cannot be accounted for.
