Head unit dash app does NOT connect to the flash pro
Supio61
Post by Supio61 »
Good morning
After upgraded Flash Pro Manager to version 4.0.4.0 the Head unit dash app does NOT
connect to the flash pro,
Cellphone connects to the Bluetooth settings on the car no problem, but when try to
connect the Head unit dash app to FlashPRO it flashes the gauges and close the program,
It was working the same day before upgrading.
Head unit dash app is version 1.6.0.0
Please advise
Thank you
Supio61
P.M. : it's possible to reset FlashPro?
Illestmike
Re: Head unit dash app does NOT connect to the flash pro
Post by Illestmike »
I have the same issue, i sent an email to the hondata support team because i need to be able to see my ethanol content
We are aware of it and working to fix it.
Supio61
Post by Supio61 »
OK, thanks
Please download the latest version of FlashPro Manager at: https://www.hondata.com/software
Supio61
Post by Supio61 »
It is connecting now
Thank you.
Travisms47
Post by Travisms47 »
So I'm having similar issues except everything is up to date.
My Flashpro will connect via Bluetooth to my phone and pc but not my HU at all
Flashpro manager is on version 4.0.5.0 and my HU is running version 1.6.0.0
My HU is also a 2019 model if that helps.
2019 Civic Si
1988 CRX Si
Ziradon
Post by Ziradon »
Something still not function well. With my iphone app and also with the HU version on my FK8 Headunit it looses connection like every 10 minutes.
I have to unplug and reconnent the flashpro over obd. Than the apps connect but looses connection after several minutes.
This problem i had also with version 4.0.3.
2020 Honda Civic Type R - European Edition
RoadconePhoto
Post by RoadconePhoto »
Just got mine today. Everything is up to date and nothing Willy connect to my flash pro at all. I’ve tried every combo of Bluetooth options on head unit, iPhone and windows laptop.
ultracam
Post by ultracam »
Hello, mine does not work as well. I'm on the latest product version of flashpro and I have the latest head unit version from the website. Have you guys found a solution yet? I have a 18 Type R and I do have bluetooth enabled. It won't let me pair to the flashpro from the headunit.
What are the actual versions of both the FlashPro manager and dash app?
ultracam
Hondata App Headunit not working
Post by ultracam »
Have you guys fixed the Flashpro not connecting to the headunit? Mine says null then closes. Hondata is on V.4.0.6 and the app is on V1.5. Please help asap!!!
Both FlashPro manager and the dash app are old versions and must be updated.
ultracam
Post by ultracam »
Hello,
I used the one from the website. Not the honda hack and I’m still having the same issue. Any fixes in mind?
