overron manifold pressure
GAOHONGXIN
Post by GAOHONGXIN »
What adjustments will be made to the data in this table? Because I now have an RDX injector, a very light flywheel, a ZDX throttle, a shunk2 manifold, and I don't know exactly why, but when I go back into neutral as I'm driving, the Revs will drop below the target revs, and then surge, in the return to normal speed, the injector restart time has also been modified, and now found that a simple adjustment of the excess intake pressure for this idle speed has a good effect
Re: overron manifold pressure
Have you tried putting the stock throttle body back on?
Please see: http://www.hondata.com/forum/viewtopic.php?t=18527
GAOHONGXIN
Spunkster wrote: Wed Feb 01, 2023 9:55 am Have you tried putting the stock throttle body back on?
My throttle body motor has been changed back to the original car, and I also borrowed the throttle that will not have this problem in my friend's car, but it is still the same.
But my friend's car hasn't changed as much as mine. He doesn't have a lightweight flywheel, an enlarged fuel nozzle, or a high-angle camshaft
