K24A IACV
FujiSpecs
K24A IACV
Post by FujiSpecs »
Hello we have a K24A in a miata and we are running it with a Kpro4 and a 02-04 rsx loom but the IACV doesn't work also the IACV is brand new from Honda, we have changed the ecu with a PRB and again nothing. I have tested the wires they are correct A12 pin for the control and 12v supply and a ground
according to this which i found on internet can someone help? Is there any reason it doesn't idle due to base map? or any other reason?
Thanks in advance
Re: K24A IACV
You have not posted your calibration.
FujiSpecs
Re: K24A IACV
Post by FujiSpecs »
That's the calibration, sorry, can you confirm that this is the correct way to wire the K24A IACV? the part number is
16022-RAA-A01
Thanks in advance
