KManager->KPro Connection Issue
Davidov
Post by Davidov »
KManager is showing "Driver Not Installed" and "Off Line" in the bottom left corner.
I am using a new USB cable from the KPro board to my laptop USB port.
When opening the 64 bit version a message shows up "USB Driver Not Installed". Following the prompt, I then see a message showing the Driver was updated successfully. The status on the lower left does not change from "Driver Not Installed"
There is a smaller circuit board that the ECU side of the USB cable plugs in to. When the cable is plugged in, there are LED lights flashing on the board.
Also, any idea what the 2-wire plug is on this sub-board? It goes to a factory looking connector under the hood that is not plugged into anything.
Going in Windows Device Manger, I do not see KPRO show up in USB controllers.
KManager shows up in USB Devices, and also in Devices and Printers.
Any suggestions?
Re: KManager->KPro Connection Issue
You do not have a K-Pro according to the pictures.
Davidov
Post by Davidov »
Well that certainly gives me something to look into!
I see now that this is a HA Motorsports-specific ECU. I thought HAMotorsports was maybe a vendor of Hondata.
