VSS PRB w/ 5speed
Yamasho
VSS PRB w/ 5speed
Post by Yamasho »
Kpro nood here.
Just installed on my 04 ep3 Canadian model
Basically stock with no performance mods yet
What can be done to make the hondata read my vss?
Re: VSS PRB w/ 5speed
What is the serial umber that is on the K-Pro board inside the ECU?
What is the ECU part number that is on the white plug inside the ECU?
Yamasho
Post by Yamasho »
K-Pro4 50003
37820-PNF-A04
Post the calibration you are using as well as a datalog showing the issue made using that calibration.
Yamasho
Post by Yamasho »
I'm using the calibration file for PNF stock k20a3
I am getting a warning message:
Calibration in the ECU is from an older version of KManager. Please re-upload the calibration before data logging.
Also error code P1298 ELD circuit high voltage.
Yamasho
Post by Yamasho »
Okay im learning as i go here.
realized my issue. i wasn't properly uploading the tune to the ECU. all good now!
speed is reading! and yes i have a PNF and not a PRB.
Still learning about data logging.
here is one from today. any tips or video diys would be appreciated!
Thanks!
