high cam fuel table
gunt
high cam fuel table
Post by gunt »
Hi
Yup , I Learning so hopefully you won't laugh ,
so i figured out how to view the high cam tables , so i can adjust , and i was , this is in the evenings , when i get a chance , i went back to it and no matter what i do it will not affect fuel , i can go back to the low tables and adjust and the afr move
i also put an injector time in the display , and no matter how i change in the high [ dramatic changes ] neither the afr or inj time move [ after loading change to the ecu ]
help please
cheers
gunt
Re: high cam fuel table
Post by gunt »
So to recap I can edit in low cam , and if I load another calibration I can edit high cam to just not the 1 I have done , I have something set somewhere wrong , any ideas
Post the calibration in question and a datalog showing the issue.
gunt
Post by gunt »
Just in case , i'm figuring out how to load what you want but so you know , i'm working of the dyno arf reading so there's none going to show in the logs , i could however send a video of the screen and you can see that adjusting the table shows no difference in the afr , i will still send it as you may see something i missed
