Flashing red light
Shneaky
Flashing red light
Post by Shneaky »
So I recently had someone install my Hondata, and when I go to connect my ecu to the laptop d2 flashes red while d4 stays green.
I tried data logging and it reads nothing. I’m guessing connection isn’t right because I can’t even upload anything.
Re: Flashing red light
Is J12 cut on the ECU?
Shneaky
Post by Shneaky »
Serial: 62553
I’m running version 2.8.1.0
Shneaky
Post by Shneaky »
And no j12 is not cut
Shneaky
Post by Shneaky »
No
It must be cut.
Shneaky
Post by Shneaky »
So there shouldn’t be a j12?
removed or one leg cut and lifted away from the board
Shneaky
Post by Shneaky »
Still flashes red
Shneaky
Post by Shneaky »
And nothing reads for datalogging
Are you able to upload?
Did the person that install it test the ECU after socketing it?
Shneaky
Post by Shneaky »
Would it light red for a second and then start flashing again if it uploads??
What happens when you try to upload a calibration?
Shneaky
Post by Shneaky »
The red light would stay on for about a second or 2 and then start flashing
