Magnus clutch solenoid setup
Lookout22
Post by Lookout22 »
I have a magnus clutch solenoid I’d like to wire up to s300 to work in first gear only. Is this possible? How would I do it, wiring is simple there’s a ground and 12v to activate it. I want it to slip the clutch on my launch and then deactivate through all the other gears. I’d like this to be computer controlled versus trying to setup and manual first gear switch
Re: Magnus clutch solenoid setup
You may be able to use the Nitrous controls to activate this. Look at the software and see if it has the parameters you want to use to activate this.
