23 Civic Type R flashpro
juddyjenks@gmail.com
Post by juddyjenks@gmail.com »
Just was wondering if there is any expected or target data for a release of a flash pro for the new FL5 civic type r
Re: 23 Civic Type R flashpro
At this time, we do not know if or when the FL5 will have FlashPro support.
ghanchin1
Post by ghanchin1 »
Hey my FalashPro Friends -1st Off - what fun I have had with your software and the FK*'s. Rock Solid.
Sold my FK8 LE - Bought an FL5.
Assuming my old FK8 FlashPRO hardware- will not work on FL5?
So I should SELL IT?
Spunkster wrote: Fri Feb 17, 2023 1:14 pm At this time, we do not know if or when the FL5 will have FlashPro support.
ghanchin1
Post by ghanchin1 »
But the question is, will it likely be a new FLASH PRO HARDWARE device?
If so, I can sell my FK8 Flashpro.
Probably not.
ghanchin1
Post by ghanchin1 »
So the current FK8 FLASHPRO Module I have will likely NOT work for the 23 FL5?
Is that what you are saying?
ghanchin1 wrote: Sat Feb 18, 2023 5:24 am will it likely be a new FLASH PRO HARDWARE device?
Hondata wrote: Sat Feb 18, 2023 2:32 pmProbably not.
Just checking back in on if any news on upcoming FlashPro for 23 tyoe r
There is no new news.
Saw the new post about the FL5 jail break and flash pro! Good work! Will the old FK8 flash pro work for the FL5 or is it a separate unit?
They use the same FlashPro.
William.Y
Post by William.Y »
Is the Jailbreak process same as FK8 ? And is the flash pro support the JDM version right now ? ECU no. 37820-66V-J03
No, the ECU must be sent to Hondata for jailbreak and there is no instant jailbreak.
Where are you located?
William.Y
Post by William.Y »
Located in Hong Kong
