2006 civic si won’t start won’t connect to ecu
Joeejara
Post by Joeejara »
k24a2 block
k20z3 head
Supertech 12.5:1 pistons
Manley rods
Acl bearings
Brand new Honda rear main seal
Type s ported oil pump
Drag cartel 3.2 cams
Supertech full valve train
Brand new honda timing chain,tensioner,and guides
Cometic head gasket
Felpro valve cover gasket/gromets
Homdata thermal intake/tb gaskets
Ported amm fab z3 intake manifold with grams dbw throttle body
Hasport pass and rear mounts
Skunk2 3.5” cold air intake
Skunk2 alpha header
Hybrid racing shifter cables
Exedy stage 1 clutch
Exedy 7.5 lb flywheel
Nx fogger wet nitrous system with bottle warmer
10lb bottle
Flashpro tuner
Grams 1000cc injectors
DW 265 fuel pump (e85 compatible) has relay
200 miles on fresh build. Went to start the car one day after it started up and drove beautiful previous day. Went to start the car day after and didn’t want to crank so I jumped it and it fired up no issues. Let it warm up and drove it 10 mins in the rain down the street before dying at a light in neutral. Pulled over and it wouldn’t crank or do anything. So I walked to Walmart a mile down the road got a battery, swap it in and now the car cranks but won’t turn over, temp gauge lights up and goes dead. Connect the car to a labtop and flash pro doesn’t detect ecu. Went thru all the fuses and relays and all seem good as well as the ground wires. Not sure as to where to check next
Re: 2006 civic si won’t start won’t connect to ecu
If you unplug the oxygen sensors, does it work?
Joeejara
Post by Joeejara »
I’m 99% the tune doesn’t use an o2
Have you tried unplugging them?
Joeejara
Post by Joeejara »
I have not! But can try. The battery is dead at the moment but once it’s charged up I’ll try
Joeejara
Post by Joeejara »
No luck with unplugging the o2 sensor
So after you replaced the battery it went dead again right away?
Joeejara
Post by Joeejara »
Cranks but doesn’t turn over. Had my tuner come by and plug in his computer and he says it’s the ecu and that it’s fried
But did the new battery drain right away?
Joeejara
Post by Joeejara »
No the battery was sitting that’s all
Are you talking about the new battery you just put in?
Joeejara
Post by Joeejara »
It was new 3 months ago. Been dealing with family issues and the car was stored at a close friends. Finally getting some time to getting around to the car and figured see what the forums had to say
When you jumped it, did you connect the jumper wires incorrectly?
Did it ever run with the new battery?
Joeejara
Post by Joeejara »
I know it may be commonly overlooked but all connections were correct. I am a 3rd year electrical apprentice so I understand circuitry. Positive to positive negative to negative. Car started up after the jump no issues and drove 10 mins about after warming up. Died at a light in neutral on me. Hasn’t started back up since even with a new battery
Joeejara
Post by Joeejara »
I sourced an ecu local and was going to grab it later if he’s around and hope my tuner can come back out and program the key to the ecu and tune it again
