Honda accord back fires
FlashPro questions & answers specific to the 2008+ Accord, Americas and international
mattfzz
Post by mattfzz »
Hey you guys I just flashed my Honda accord for the second time now with my borla exhaust, front pipe from Prl, and a prl cold air intake V1. This second time around the car crackles when I rev it now. I did the exact same pre map stage 1 tune as I did a year ago. It crackles or burbles more than when I first did it a year ago. I thought it might be an exhaust leak but no light has come up. I also retightened all the bolts. Should I be concerned? Is it normal
Re: Honda accord back fires
It may not be running right. You will need to look at the datalogs and see what it is doing.
ajgarcia
Post by ajgarcia »
You can also check your injector over run times and the fuel cut and recover rpms. I remember with my 2012 Accord it would crackle and burble all the time coming off throttle at 1800 rpms with no tune, which is right around where the fuel cut is on the stock maps.
