Will cpr get around bad dizzy error?
touge tom
Post by touge tom »
Like the title suggests we'll CPR kit get around the bad distributor error? I've tried 3 different distributors And still have no spark I have checked all continuity between the between the 7 pin connector and 2 pin connector they are all fine
Re: Will cpr get around bad dizzy error?
What is the error?
touge tom
Post by touge tom »
No cel codes. Just in sensor list the dist,error is on and no spark
No, it will not fix a problem like this.
touge tom
Post by touge tom »
I checked the power supply to the 7 pin plug I have negative supply but no positive supply to the 3 sensors in the dizzy.
touge tom
Post by touge tom »
Spunkster wrote: Fri Feb 24, 2023 11:36 am No, it will not fix a problem like this.
I just checked the pinouts on the p28 ecu I have negative to all 3 dizzy sensors and no positives does this mean the ecu is shot?
Have you tried the ECU on a known working vehicle?
