Calibration for stock LSVTEC or GSR Calibration?
drollersoup
Post by drollersoup »
Would a stock GSR calibration be able to work with this mostly stock setup or should I run a LSVTEC Specific basemap for first start up?
81mm Ls Vtec
GSR head
Stock valvetrain
Stock GSR cams
Stock Manifold
Stock Throttle Body
Stock Injectors
B18B1 Block
Stock PR4 Pistons
Stock Rods with ARP rod bolts
Pretty much stock everything which I why I should be able to run a pre set calibration in Hondata, right?
This is my first time starting a motor after being rebuilt so any feedback or criticism is welcome!!!
Any info helps, thanks!
Re: Calibration for stock LSVTEC or GSR Calibration?
You will have to try it and see how it runs.
