Second hand Hondata Fuel Kit & HPFP already enabled without code?
Natious
Post by Natious »
Hi,
I have a quick question, I have also messaged facebook with no response.
I have purchased a used hondata fuel system kit, before knowing that the "code" was locked to the original flash pro.
The seller managed to track down the person who bought his flashpro and I swapped mine for his, great!
Although, under the Fuel Pump menu it indeed does say HPFP enabled although there is no codes in the box below nor can I enter any text, but the strange thing is on my original flash pro it was exactly the same, HPFP enabled and unable to enter any information.
So, did I not have to swap my flash pro over, is this flash pro going to work?
Some confirmation would be great.
Thanks.
Re: Second hand Hondata Fuel Kit & HPFP already enabled without code?
Have you opened a calibration in the software?
Natious
Post by Natious »
I have edited my current calibration to include the hondata fuel system, flash pro did not give any errors, the Fuel Pump tab remains enabled although the code area remains blank and unable to enter anything.
Natious
Post by Natious »
Ok, will do, so we don't know if it will work or not as I planned to install this weekend.
Natious
Post by Natious »
I have sent the feedback as requested :)
replied via email
