2016 Civic EX-T
Civic 2016+ 1.5 Turbo
SHolmes
2016 Civic EX-T
Post by SHolmes »
I flashed back to stock and unlocked but have repetitive codes that will not go away , I have done a few times , disconnected the battery before each attempt . said Civic has a PRL short ram CAI , Map stainless high flow exhaust and a PRL Flex Fuel which I have not set up . It keeps giving me a oxygen sensor heater bank 1 sensor 2 code ( P0141 ) and Software incompatibility with Engine Control Module / Powertrain Control Module ( U0301 ) when I try to erase it states Command Rejected ........ any help would be appreciated .
Re: 2016 Civic EX-T
Is this only when returning to stock from the online menu?
SHolmes
Re: 2016 Civic EX-T
Post by SHolmes »
As far as I know ... even after the parts and flash done the check engine light was always on ... I need an inspect and cannot get those 2 codes off since parts and flash . I'm an old school V8 kinda guy but was amazed at the power the lil Hondas put out .... not so much presently
Re: 2016 Civic EX-T
Are you uploading a 16, 17 or a 16-17 calibration?
SHolmes
Re: 2016 Civic EX-T
Post by SHolmes »
When asked first about returning to stock there was a prompt about it can only go back to a 2017 stock flash but it did not after that ....
SHolmes
Re: 2016 Civic EX-T
Post by SHolmes »
Is there any truth in Honda releasing a software update to the CVT that needs to be done by them .... and is the high flow down pipe causing the o2 issue ...
SHolmes
Re: 2016 Civic EX-T
Post by SHolmes »
Why can I not delete codes with a scan tool , after the flash it states command rejected ...
Re: 2016 Civic EX-T
When you upload a calibration what year calibration are you uploading?
SHolmes
Re: 2016 Civic EX-T
Post by SHolmes »
2016, is there an easier way to communicate ..... Ive tried calling no resonse
Re: 2016 Civic EX-T
Upload a 2016-2017 calibration and that should work, as it sounds like your vehicle has the oil dilution update from Honda and they updated the transmission controller to the 2017.
