K20A3 running poorly, k24a2 swap
Ajsbored94
Post by Ajsbored94 »
Just picked up an ‘03 5spd base RSX with a PND Kpro ECU. Seller was running a k20a3 with a skunk intake manifold, k-tuner fuel rail, and cheap eBay headers. I have an ‘06 TSX Auto K24A2 that I plan on swapping over once the rebuild is done.
Will the PND Kpro that came with the car work with the k24a2 swap? I’m hearing that I’ll need a PND AUT Kpro ECU and other conflicting things regarding the ECU and Kpro.
Re: K20A3 running poorly, k24a2 swap
Are you planning to use an automatic transmission?
Ajsbored94
Spunkster wrote: Thu Mar 16, 2023 4:32 pm Are you planning to use an automatic transmission?
No sir, I’m keeping the 5spd transmission that came with the RSX.
What you have should work with the engine you are planning to use.
Ajsbored94
Spunkster wrote: Thu Mar 16, 2023 4:42 pm What you have should work with the engine you are planning to use.
Thank you!!
