How can I adjust Flashpro after installing TR3 cams?
ARCLIU
Post by ARCLIU »
I installed TR3 cams for FK8 Type R but it will show VTC failure
Can anyone tell me how to adjust vtc in Flashpro?
Let me drive normally for a while
Because I still have the hardware not finished yet, I can't find a tuner to adjust it.
Re: How can I adjust Flashpro after installing TR3 cams?
If the camshaft is made with incorrect phase wheel alignment then it is something that can not be corrected in the ECU.
leechihfei
Post by leechihfei »
You have to log the Camshaft data & ensure your CamCMD figures match the logged data, not exceed them.
Exceeding these logged Camshaft numbers with the standard VTS CamCMD numbers, will trigger the error.
4pistons mentioned in their blog, & explain the process to resolve this
