K24a2 swap 8th gen need basemap
K24a2 , stock injectors , stock rbc intake manifold, 3 inch Sri intake , plm headers , 3 inch full exhaust, 50 degree vtc cam gear , type s oil pump , walbro 255 fuel pump , full stage 4 clucth . I’m in need of a basemap until I get it dyno’d soon
Car runs and drives , just won’t go over 4k
- CalibratEd
- Contact:
Re: K24a2 swap 8th gen need basemap
Post the calibration you are currently running with a datalog. This might be an issue unrelated to the tune.
-Ed
-Ed
Instagram: calibrated.tuning
Just a quick little drive
Morning commute regular stop and going
- CalibratEd
- Contact:
Post the calibration file as well.
-Ed
-Ed
It’s in a basemap from a tuner and it’s locked , he’s not very responsive quickly that’s why I need your help . I can’t see the calibration because of his pass code
- CalibratEd
- Contact:
I don't understand why tuners lock their tunes. The log shows the car is running lean. It could be that it is running so lean it will not let you rev past 4000rpm or the tuner might have placed a limit so you would not drive the car to hard. Without access to the calibration file I cant tell much more.Nharris99 wrote: Sat Apr 01, 2023 1:35 pm It’s in a basemap from a tuner and it’s locked , he’s not very responsive quickly that’s why I need your help . I can’t see the calibration because of his pass code
-Ed
Do you think you can start me off with a different basemap or something? This situation is just inconvenient for me
- CalibratEd
- Contact:
I can help you out with that. When is your dyno tune?Nharris99 wrote: Sat Apr 01, 2023 8:10 pm Do you think you can start me off with a different basemap or something? This situation is just inconvenient for me
-Ed
Haven’t set it up yet, I was hoping within the next month or so. For now i just wanted a simple fun basemap until the dyno pretty much . I have some more logs I did today I can upload them if you want
- CalibratEd
- Contact:
I have would reconsider where you are getting tuned if you are already having trouble. There is no need to post logs as they reflect the current calibration file you are running. I will work on a base when I have down time. For now take it easy on the car. If you want you can also use a Hondata base map and I can make some adjustments to make sure it’s running safe.Nharris99 wrote: Sat Apr 01, 2023 9:21 pm Haven’t set it up yet, I was hoping within the next month or so. For now i just wanted a simple fun basemap until the dyno pretty much . I have some more logs I did today I can upload them if you want
-Ed
- CalibratEd
- Contact:
Load this file and see if you can get an idle and normal drive log. I will make broad changes to make sure the car is running safe.
-Ed
-Ed
