K24a2 with TSX 6 Speed MT
tumul21
Post by tumul21 »
Looking to do a swap, unsure of the chassis just yet, but trying to get parts together. I have a k24a2 with tsx 6 speed transmission and I'm trying to figure out if Kpro will work if I obtain a RSX ecu and wire harness?
From the transmission technical data, this is what I'm seeing I would need to do:
"Converting a high frequency transmission to a low frequency transmission:
Either drill and tap the rear speed sensor location to accept the 02-04 speed sensor, or swap transmissions cases.
Add the speed sensor drive ring to the final drive."
It appears a TSX transmission is high freqency? Is this the case for all?
Found in the 05-06 RSX, TSX and 06-07 Civic Si.
Signal from the speed sensor is at a high frequency.
Speed sensor is at the front of the transmission, from the teeth on 3rd gear.
The signal from the speed sensor goes only to the ECU. The ECU sends a low frequency signal to the gauge cluster."
Thanks in advance for any help. New to all this and trying to learn.
tumul21
Re: K24a2 with TSX 6 Speed MT
Post by tumul21 »
I guess I can swap out the speed sensor on the TSX with a k20?
First you need to determine what vehicle this will be used in.
