ECU 37820-PND-A59?
rufusbob
ECU 37820-PND-A59?
Post by rufusbob »
How do features of the -A59 ECU compare with others in series 37820-PND-A01 thru A04 and A06-A09 (I.e.manual transmission PND’s)?
Is -PND-059 KPro compatible and possible to use for a K-swap vehicle?
Thanks,
Bob
Re: ECU 37820-PND-A59?
What vehicle is this for?
rufusbob
Post by rufusbob »
‘04 RSX Base. Shown as currently available on Acura parts site:
https://www.acuraautomotiveparts.org/oe ... wtbDQtZ2Fz
That ECU is compatible a long as it is only used in a swap vehicle. Details on using an auto ECU can be found at: https://hondata.com/tech-alternative-ecu-engine-swap
rufusbob
Post by rufusbob »
Thanks.
So after rerouting the VSS input from the wiring harness to the KPro4 board patch harness:
1) is it correct that the alternate KPro4 VSS input signal may come from either a countershaft sensor or a ring gear sensor as long as the appropriate pulse / km setting is made in KManager?
2) the -PND-059 will support the same features (VTEC, IAB, knock sensor and factory wideband O2) as the other PND manual transmission ECU’s?
Your help is much appreciated.
yes and yes.
