Will kpro work with my setup
EGmando
Post by EGmando »
I am currently running Ktuner on my swap but am looking to switch over to KPro and wondering if this would all be compatible.
Chassis is a 93 EG hatch with a JDM K24A block and head.
My transmission is a 5 speed from an 07 accord. i believe i will need to get a vss converter to make the cluster and vss read properly correct as the tranny is an 07 with a high freq sensor.
Im not gonna go into detail on what mods it has i don’t think its important i just wanna know if kpro is usable here with the general setup. I know i will need a new conversion harness for the chassis AND an 02-04 engine harness because I am using 05-06 rsx ecu and pinouts with the respective harness. Assuming i get a new harness and 02-04 ecu, KPro will work correctly? my main concern is the transmission working properly. Based off what i have read as long as i convert the vss to a low frequency everything should be solid.
Am i missing anything or will this be a straightforward swap with the respective ECU, conversion harness and engine harness?
Re: Will kpro work with my setup
You should be able to use a K-Pro as long as the harness and ECU are changed as you have said.
EGmando
Post by EGmando »
Spunkster wrote: Wed Apr 12, 2023 4:29 pm You should be able to use a K-Pro as long as the harness and ECU are changed as you have said.
I see so there should be no issue using an 07 tranny as long as the vss is converted to a low frequency? Which ECU would you recommend or would any kpro ecu work as long as it is an 02-04
Yes that transmission will work. A complete list of compatible ECU's can be found at: https://hondata.com/tech-rsx-ecu-reference
boosted72
Post by boosted72 »
Hi all: More VSS questions. Confused! I know, me too. I think I have the best question about what VSS sensor to use with Kpro 4.
Can I use a 2 wire VR type vss sensor? This sensor always sends a low frequency signal but has no voltage supply. This is like all GM cars and most ABS sensors. I have read from Hondata.com that Kpro4 can use almost any vss sensor! There is no other information after that.
I am running a GM fwd 4t65e transmission in my Kswap and now want to use boost by gear because the tire spin is massive even with my lsd ( both tires are spinning). I am using a rear wheel non driven vss sensor not the transmission of course.
I think no one knows the answer. Thats ok. I am just going to try this first as it has almost no voltage power output.
I think Hondata could of supplied a lot of tech. info on their board for vss input requirements and limits ect.
Anyways that's it. Look forward to what you may know and will post after I complete this mod to my build.
