MAP Channel stuck
terrorista
MAP Channel stuck
Post by terrorista »
Guys,
I Switched to Hondata's 4 bar map sensor and .. For some reason everytime the car is shut off, the MAP channel stuck in this reading.
If I disconect and reconect the MAP Sensor, the engine dies, but when firing it again it reads ok.
Just turn it of and refiring ... Gets stuck.
Attached Cal and Datalog of the situation.
Re: MAP Channel stuck
If you put the stock MAP sensor back in does it do the same thing?
terrorista
Nope ..
Just change back to the 1.7bar MAP sensor despite using the 4bar map calibration ... It varies as desired.
I´ve added a Datalog with it.
I´ve tried two 4 bar map sensor ... Hondata and PLM .... Same stuck situation when turning off the engine.
Thanks,
Put the stock MAP sensor back in and reupload the calibration with the correct settings for that MAP sensor and datalog. Post that calibration and datalog here.
terrorista
Guys,
Attached the Calibration and Datalog with OEM MAP .. I stop and refire the engine to confirm MAP reading.
The calibration is locked and I cannot see any parameters. If the calibration is not setup correctly for the MAP sensor you are using then it will not work.
terrorista
My Bad ...
Attached fully unlocked.
The calibration is locked.
terrorista
Sorry again ...
Please Advise.
Cheers,
The datalog you have posted is blank and contains no data. Are you trying to use the OEM map sensor with a calibration set for a 4bar?
You need to post a datalog using the 4bar MAP sensor and the calibration you have posted
terrorista
Guys,
Attached the calibrations unlocked and the datalogs:
4 bar Map Stuck
OEM MAP - Reading normal
Please advise.
What has been modified on this vehicle?
From what you have said, the 4bar works until you shut the engine off then it doesn't read after restarting...is this correct?
What wiring has been modified in the vehicle?
terrorista
Hi Spunkster ... Sorry by the late response.
Happened again with another car ... We got like ... 7 cars doing it ...
The Map chanel just read the same value / Colum - All other Readings are OK.
I tried to flash it, change the map on the calibration, flash it again and .. Nothing changes. Once I put the key on 2nd stage (Dash and all systems ok) i need to take map the connector out and on the sensor. Doing this, the readings get ok ... Car runs fine ....
When I shut off the engine, when re-cranking it ... It gets stuk again.
Tried with several MAP brands, including your ones ... Nothing changes.
No one else has reported any issues like this.
terrorista
Spunkster wrote: Fri Apr 26, 2024 12:29 pm What wiring has been modified in the vehicle?
Only have the Boost Controller as EGR Lift at pin B2.
And WideBand as ELD at pin A23
