Can't use iOS Hondata app, or head-unit app with FlashPro for 2020 FK8
julianstogs
Post by julianstogs »
TECHNICAL INFO, SOFTWARE VERSIONS, ETC.
Vehicle
2020 FK8 (USA)
FlashPro Info
Race edition
Serial: FP-CTR-FK8-355525 (2017+ Civic Type R Americas)
Firmware: Updated yesterday, right after updating to the latest FlashProManager for desktop (v4.0.8)
iOS Info
Device: iPhone 12 Pro Max
iOS Version: 16.3.1
Hondata app (iOS)
v1.5.1 (released 3 weeks ago)
Installed when purchasing the "Hondata Complete" package
Hondata app (free, head-unit version)
Installed latest v1.6.0.0 from Hondahack's online installer, as well as USB/APK method where APK was downloaded directly from Hondata website
ISSUE DESCRIPTIONS
iOS App Problem
I downloaded the "Hondata Package" which includes the "Hondata Complete" and "Auto Logger Pro" apps. With the Hondata iOS app, v1.5.1 (released 3 weeks ago) the app is either incorrectly reporting, or incorrectly receiving engine data updates.
"Connection with response" Enabled: The app will continuously search, and connect to the Flashpro, but disconnects again immediately after connecting. This will happen continuously.
"Connection with response" Disabled: The app connects and stays connected to the Flashpro, however most of my gauges do not update. RPM value flickers with values that do not match the actual engine RPM, and the graph/gauge does not animate. This is the case for most of my sensor values. The only thing that seems to be accurate is my coolant temp. (I compared coolant temp to the temp reported by the CarPlay LogR app from Honda)
Hondata head-unit app
2020 FK8 Hondata head-unit app cannot connect to the Flashpro. When I press the connect button, I am presented with a device list that shows my Flashpro, but every single time I try to connect the connection status shows "Connecting to null..." and then "Failed to connect, retrying" (or something similar) and then the app instantly crashes/force-closes.
I have emailed support, and provided videos / photos to make reduce back-and-forth questions, but hoping I may get some assistance more quickly here. This flashpro was brand new, I just received it on 4-12 or 4-13 of 2023. One of the main reasons I chose the FlashPro over other tuner options, was because the Hondata apps looked so great. They had great reviews, but I'm not getting a little disappointed. Hoping that there's something simple to fix this, whether it be resetting the FlashPro, using a different version, or a small code fix with a new update released.
Re: Can't use iOS Hondata app, or head-unit app with FlashPro for 2020 FK8
Fkay8
Post by Fkay8 »
I have the same issue, I had a cable version and everything was working fine but with the Mini version, I can’t pair it with my 2021 FK8, I tested my FlashPro on another 2017 FK8 and everything works perfectly, so I assume the FlashPro itself is fine.
Hondata is there anything that I could do to establish conection between the Flashpro Mini and the 2021 FK8 Head Unit?
We don't have a crystal ball. Please provide some information like the OP.
Fkay8
Post by Fkay8 »
Vehicle
2021 FK8 European Domestic Market
FlashPro Info
EPA/CARB Compliant: No (out of USA or competition vehicle)
Serial: FP-CTR-INT-372810 (2017+ Civic Type R International)
Software version 4.5.5.0
Firmware: Upload Version 4.5.3.0 Main version 267
Hondata Android (Dash) APK file (from the Bluetooth tab on the Flashpro Manager)
Version 1.6.0.0
I already tried to enable and disable the Alternative pairing mode for head unit (2018+ Civic) with no results. I had the cable version since 2022 and worked fine, at the same time I bought another Flashpro Mini (FP-CTR-INT-372808) to tune a costumer car (2017 FK8) and is working fine, I tried this Flashpro Mini (FP-CTR-INT-372810) on the costumer car and works ok, on the costumer car I'm using the same Software and Firmware versions as well the same APK file version 1.6.0.0
Let me know if you need more information
Fkay8
Post by Fkay8 »
Just some quick update to let you know that I installed this new software version 4.5.6 and the new 269 firmware but the issue remains the same.
Fkay8
Post by Fkay8 »
Hondata is there any more info that I could provide in order to help solving this issue?
