Nitrous controls not working
Lookout22
Post by Lookout22 »
I’ve got my ac clutch output wired to a solenoid (on the ground side) when I test the output of the ac clutch the solenoid activates like it should. I can’t get it to activate through nitrous controls though. I have a switch wired to b5 ac switch, I can see in the sensor bar that my switch is operating correctly, I can watch it turn on and off on the screen. I am trying to use this switch input to arm my acc wired solenoid. I have all the conditions set so that the solenoid should be activated all the time unless vss is over 10mph. I can’t get it to work at all, if I disable the input and check the “invert output” box the solenoid comes on, but the conditions don’t affect it and the switch still won’t do anything. I’m not sure what I’m doing wrong here! Please help
Re: Nitrous controls not working
Post the calibration and a datalog showing what is happening using that calibration.
Lookout22
Post by Lookout22 »
calibration and datalog are below. in this log it shows me turning the switch on and off but the ac clutch is not coming on. the only times that it does come on is when i use the test output feature, switches on and off no problem then!
Try changing the minimum throttle to 1 and the minimum speed to 1 and make sure those conditions are met.
Lookout22
Post by Lookout22 »
I did that, made no difference if I check “invert output” it will stay on but I have no control over it, it’s stuck on. This is annoying as hell
Lookout22
Post by Lookout22 »
How does the invert input and output thing work anyway ? If I invert the output does that mean it’s sending out a 12v signal instead if it’s normally a ground?
Inverting just changes whether it is on or off when activated.
