FL5 Hondata factory and 91/93 flash tunes
Fkay8
Post by Fkay8 »
Just out of curiosity why on your Hondata FL5 91 and 93 flash tunes you don't use the air charge limit table and on the FK8 tunes you use it?
Another thing that I saw is that on the factory FL5 calibration the general torque limit table have some lower values compared to the request torque tables, I can't understand why is programmed this way.
Thanks in advance
Re: FL5 Hondata factory and 91/93 flash tunes
We just used a different air charge limit table. 'Turbo max air charge' vs 'Air charge limit'.
The second question you would have to ask Honda/Bosch.
Fkay8
Post by Fkay8 »
Hondata wrote: Thu Apr 20, 2023 3:50 pm We just used a different air charge limit table. 'Turbo max air charge' vs 'Air charge limit'.
Could you please show me this table
I understand your point, Honda/Bosch have some logic on this point that I don't understand.
Tables, 'Turbo Max Air Charge (IAT)'
Truu
Post by Truu »
Hondata when I load the 93 tune just as it is, a couple of us owners are getting an overboost code. Do you have a solution to that?
@Truu.CTR
What version of software have you used to upload? Did you read the release notes for FlashProManager 4.0.9?
Truu
Post by Truu »
I am currently using 4.0.9 and I get these codes currently. RV6 DP drop in filter and non res exhaust Image
@Truu.CTR
Ok, more specifically then - what is the minimum map pressure set to in your calibration?
yuzzimi
Post by yuzzimi »
Hi,
I'm having the same issue with P0234. I downloaded my the manager on 4.20.23. What are the steps/procedures to adjust the tune to eliminate the DTC? I currently have a Milltek exhaust and front pipe and drop in filter (not sure if that affects anything). I have a CTR FL5.
yuzzimi
Post by yuzzimi »
Current version V4.0.9.0 2023-04-19 (715 MB)
It is to do with the rev hang. If the throttle is released from redline then the manifold pressure falls much faster than the ECU expects, and the ECU reports this as an overboost condition.
So either disable P0234 or un-select the rev hang mod or wait until later tonight for another release.
Please see info at: viewtopic.php?p=131237#p131237
Truu
Post by Truu »
Thank you I disabled the p0234 after the update. Now to patiently wait for everything to be open so I can put the P700 in
@Truu.CTR
yuzzimi
Post by yuzzimi »
How do you disable the DTC. newbie here.
