NTK Gen 2 to KproV4
claroz
NTK Gen 2 to KproV4
Post by claroz »
Hi
I`m trying to hook up Wideband NTK Gen2 to Kpro.
I`ve seeing all wiring diagrams and try the diagram as
for NTK AFX but the AFr info at KproV4 is not the same
as the one in the wideband monitor.
Re: NTK Gen 2 to KproV4
Have you entered the correct voltage conversion for the wideband you are using?
claroz
Post by claroz »
Thank you for your answer. In all the instructions I don`t any info
about the voltage conversion. I`ll check again or maybe you can tell
me what voltage conversion to apply?
Is this just a sensor, or is there a controller for it?
claroz
Post by claroz »
It`s NTK Air fuel Ratio Monitor Gen2 with it`s sensor.
You will need to look at the documentation to see if it has the same voltage conversion for AF that one of the other listed widebands uses. You cannot run closed loop from a custom wideband input. Only the listed widebands will allow you to run in closed loop.
claroz
Post by claroz »
Thank you for your help. I check the documentation and found the voltages.
I will do it and see if works.
claroz
Post by claroz »
Good night.
I`ve read the documentation trying to hook up NGK Gen 2 to Kpro V4.
It`s being impossible to log so I decided to change to an AEM wideband
35-3401 and this one as the NGK gen 2 it`s not listed on KproV4.
Maybe you know the voltage offset to this AEM wideband.
Kind regards
If wired correctly the voltage offset should be close to zero.
